Speaker set up cd or dvd?
Discussion in 'Home Cinema Speakers' started by cdb, Feb 7, 2005.
  1. cdb
    cdb
    Mar 1, 2003
    475
    28
    +47
    Is there a set up CD or DVD that can send set tones to each speaker in turn as opposed to all at once, so you can do a frequency curve for each speaker and so set them all the same, within the provisions of your amp? I have some tones from the internet, but they're pretty much a waste of time as they're all for the sub.
    I've set my speakers up using the test tone on the amp (avr2805) so they're all the same volume, but I don't know if there's any dips/peaks or whatever in the frequency curve.
  2. cdb
    cdb
    Mar 1, 2003
    475
    28
    +47
    I take it there isn't one then? :(
  3. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    I don't know where you found your internet test tones but the snapbug site has a range of tones all the way up to 1000Hz plus a couple of sweeps too
