Speaker recommendations
Discussion in 'Desktop & Laptop Computers Forum' started by jayjay, Feb 9, 2002.
  1. jayjay
    jayjay
    Jul 18, 2001
    353
    nwsex
    +8
    I've built myself a pretty good PC - GF3, SB Audigy (with the int drive), Pioneer slot DVD, etc. I need to get some speakers for basically playing games and watching the odd DVD (I have a full HC set-up in the living room downstairs).
    What are my options here? I want 5.1 sound but don't really want to pay the earth. I have a Sony DD amp spare but I wouldn't mind flicking that on and putting the cash towards some speakers - using the Audigy's internal processing.
    I've seen the Creative speaker packages but they look pretty lightweight - but affordable.
    Any ideas??
    Jay
  2. zigguratt
    zigguratt
    If you're using an amp, it would be hard to do better than the Diva Swans. Scroll down to find the 2.1s, 4.1s, etc. They're ridiculously low-priced for such high-quality, beautiful speakers.
    If you're not using an amp, the Klipsch ProMedia 5.1s are excellent speakers. You would be blown away by their power and clarity. I have the 2.1s on my computer for casual listening and I'm constantly amazed by these speakers.
  3. jrwood
    jrwood
    What aboute the DigiTheatre DTS? , Im currently wondering whether to base my audio system on the HTPC/HCPC or buy seperates.
    I suppose if I go the PC route then any new algorithims in PowerDVD like Dolby Prologic 2 is cheaper than upgrading to a new AMP..
    Although I doubt a PC based speaker system is anywhere near the quality of a £600 amp/speaker seperates system?
    James (htpc with sblive 5.1)
  4. jayjay
    jayjay
    Jul 18, 2001
    353
    nwsex
    +8
    Thanks guys
    zigguratt
    Thanks heaps for the links. I'll check out the Divas - haven't heard of them before and not sure I could get them in NZ. I'll do some research.
    The Promedia's look the business but they're quite expensive here in NZ. The 4.1's cost NZ$950 so god knows how much the 5.1's will be! Do you know if the 2.1's can be upgraded to the 5.1's? They're "only" NZ$560!
    James
    DigiTheatre? Haven't seem them either, are we sheltered down here or what! I'll try and find them too!
    Sorry I can't answer your question HTPC vs separates. Upgrading software is an advantage but I think your soundcard probably has a big say in how high quality your set-up is. I thought that Dolby P2 was only really useful for VHS anyway?
    Jay
  5. jrwood
    jrwood
    Dolby Pro Logic 2 is useful for TV, I believe any DPL signal sounds far better in DPL2.
    There are loads of reviews of Videologic's Digitheatre 5.1 DTS being the one Im thinking of getting. Ive posted a few links but there are plenty of reviews.....ahh decisions! - let me know which one you go with and why you went for it :)
    http://www.3dsoundsurge.com/reviews/DigiTheatreDTS/DigiTheatreDTS.html
    James
