Speaker recommendations to suit Denon 3805
Discussion in 'Home Cinema Speakers' started by Rob100, Mar 7, 2005.
  1. Rob100
    Rob100
    Nov 3, 2002
    3,485
    +227
    Hi there,
    Just toying with some ideas...
    At present my Denon 3805 is driving the following speakers:
    Fronts - Tannoy MX2's
    Center - Tannoy MXC
    Rears - Tannoy MX3's
    Sub - PSB Sub Zero
    I know the speakers don't do the Denon justice so I'm considering replacing the fronts and centre with something better and move the MX2's to the rear. Then in the future is we move I can hopefully use the MX'3 again and have a 7.1 system should the room layout allow.
    Definately looking a floorstanders for the fronts. A maple/beach finish is prefered. I have no idea on budget, but some "sensible" idea's would be welcomed and I'll go from there.
    Main use if for movies/TV, but would like the fronts to be good for use in stereo mode for music (without relying on the sub for bass assistance).
    Thanks in advance.
    Rob.
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    I would recommend you look at the monitor audio silver series and the quad range. both do great speakers I have the monitor audio myself and also demoed the quad 11l speakers.
  3. krungthep56
    krungthep56
    Oct 1, 2004
    178
    Cheshire
    +6
    Have the 3805 and 3910 with Quad 11L's which sound sublime. I am also fortunate to live in Asia where the Quad's cost a tad under 250 quid!
    Regards and happy listening.
    HT
