Speaker / Receiver quandry
Discussion in 'Home Cinema Speakers' started by sniffer, Dec 13, 2004.
  1. sniffer
    sniffer
    Jun 5, 2003
    I've been going out of my mind during the last couple of weeks trying to decide on a decent speaker / receiver setup for home cinema & to play a few cds. Reading plenty of posts on this excellent forum has confused me to the point of my brain imploding.
    The receiver i require must have audio delay, cos im connecting to a plasma & 2 component inputs minimum as i will connect my xbox & dvd player to it.
    A nice extra is automatic setup.
    The receiver i had in mind was the denon 2805 - about £550 or Yamaha 1500 or 2500 (from germany approx same value).
    I thought i had decided on a set of canton movie 10 speakers but when visiting a local hifi shop they told me that i should be spending twice the amount of money on the speakers as the receiver.
    He suggested a bose system with multiple cubes i think it was acoustimass 10 - £800.00. This would blow my budget just on speakers alone.
    Would the receiver be too much for the cantons?
    How big a difference between the cantons & bose?
    Any help would be appreciated.
    Thanks in advance
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    This is a personal preference, but I would avoid the Bose if I were you. There is greater bang for your buck elsewhere.
    Have never heard the Cantons so can't comment, but what are you looking for, floorstanders/standmounts/ sub/sat?
    I wouldn’t necessarily go along with the assumption that you should spend twice the amount on speakers than the amp, but certainly imo you should spend more on speakers than amp.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    i agree about spending more on speakers (but not on BOE as they will waste the money spent on AMP.....) as the AMP will be a media HUB for future plasma then 50-50 split on AV amp speakers is fair........ if you like cantons look at CD2.22
  4. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    The CD 2.22 look great, I was thinking of ordering these from Germany at one point, but didn't have the guts to go for a blind purchase. :blush:
    Try AV Sales in Kent though, as they have the Caontons to demo and are very friendly & professional :thumbsup:
  5. sniffer
    sniffer
    Jun 5, 2003
    Thanks for the advice.
    Your right the canton 2.22 do look the business.
    At £700 it is still outside my budget but I may have to do the ironing, washing, hoovering, wining & dining for a while to soften up the wife.
    cheers
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    much better to spend £700 on Cantons instead of BOSE
  7. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    Sound advice :thumbsup:
