Speaker Question For Newbie Please
Discussion in 'Home Cinema Speakers' started by bigjonnyauk, Jul 28, 2003.
  1. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    726
    midlands
    +16
    HI ALL
    I HAVE ONLY BEEN INTO HOME CINEMA FOR ABOUT A YEAR NOW AND LOOKING AT ALL THE LOVELY KIT YOU GUYS HAVE MAKES ME FEEL A BIT EMBARRESSED ABOUT MY SET UP lol
    but i am now looking at other options of upgrading but cant do it all in one go so here goes
    i have a phillips mx980 home cinema (yes i know its not the dbs like you guys have but cost me 300 and at the minute im very happy with BUT
    i wonder just how great it could be with seperates
    if i started buying just speakers and sub could i connect to the amp/receiver until i can afford another amp or vice versa
    also just how much difference will i see as i said im a newbie but am very happy with my system at minute but like everyone want something better
    also i still cant fully understand this setting my speakers to large or small what difference does tis make i currently have all set to small AS THEY ARE but when the bass kicks in it sounds how can i put it muffled but when i set to large it seems a bit clearer why is this
    SO WHEN YOU STOPPED LAUGHING any advice would be nice
    ps i was looking at that denon 1803 from empire and the eltax speakers from richer 250 quid i think they were
    i am on a tightish budget so cant go into hundreds and hundreds is it best to stick with what i have due to limited funds ?
    thanks
  2. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    dosent matter what you have,you have to start somewhere,as for speaker settings check some older threads on this board,i did and found plenty of good advice from the good old boys on this board,
    come on lads give him a hand:clap: :D
  3. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I have had a look around the internet and can find out very little about the Philips MX980 except that it is a combined DVD player, receiver and speakers.
    It may be possible to upgrade parts at a time but I can't say for definite until I know what all the connection options are.
    I have no doubt that the Denon amp and Eltax speakers will provide much more quality for you but you may also need to buy another DVD player if you can't output from your existing unit to a seperate amp.
  4. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    726
    midlands
    +16
    my mx 980 mate does not have a inbuilt dvd player it is just an amp/reciver speaker package i have a toshiba sd 220 multi region dvd player the amp has loads of inputs lol
    ill try and find a link mate there has to be one somewhere lol
  5. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    726
    midlands
    +16
  6. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    If the speakers are connected to the amp it should be possible to upgrade them seperately and I would upgrade the speakers first and the amp second as the quality of the speakers has a greater effect on the whole than the quality of the amp.
    That is speaking generally though and you won't notice a really great improvement until both amp and speakers are replaced.
  7. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    726
    midlands
    +16
    any ideas on certain makes that ae good i am prob limited to about 250 maybe able to push 300 for speakers and sub
    i was hoping to sell mine to fund the new amp?
  8. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    If you can run to the Eltax speakers from Richer Sounds I wouldn't bother with a sub at the moment. As long as you have reasonably full range speakers you can leave the sub until after you have replaced the speakers and amp.
  9. Smurfin
    Smurfin
    Aug 13, 2002
    20,650
    +4,005
    Eltax liberty 5 would be good for mains, only £99 per pair. I'm currently using a pair for my PC with a Cambridge Audio A5 amp. Nice floorstanders, good bass (espcially if you have a small room).
    I'd agree with Ian re: leaving the sub for now. Buy an eltax set from RS if you can then save up for a sub later.
  10. menalaus
    menalaus
    Apr 25, 2003
    338
    sleepy hollow
    +6
    hi, for the amount of money you have available i wouldnt waste it buying new very budget speakers e.g Eltax etc as you will very soon become frustrated buy them as you upgrade the other components of you system. spend the money buying 2nd hand from other users of these forums (or even ebay, but mind you dont spend over the odds in all the excitement of the auction) you will definately get more for your money.
    i would consentrate on the front L/R and centre as you can use your existing speakers (or any old hifi speakers, as they wont need to be shielded) for the surrounds. e.g you can pick up warfdale diamond fronts for under £100 new (c/o ebay) and pick up the well respected ( in budget terms) warfhdale valdus centre for around £20 leaving money for a sub and cables when they come up for sale. this is just one example of many options that will blow 'budget packages ' away.
    Ian J makes a very good point about waiting to get the sub. a bad sub is worse than no sub at all IMO.
    if you can live with your current set up then do until the right stuff comes up for sale.
  11. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    726
    midlands
    +16
    oh yes i am very happy with what i got at minute so can easily wait until the right stuff comes along
  12. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    told you you'd get some help ,good bunch here.
    good advice about the sub,get good speakers first.:clown:
  13. Smurfin
    Smurfin
    Aug 13, 2002
    20,650
    +4,005
    Only thing you may have difficulty with initially is "spotting" those good bargains in the AV classifieds, if you're reasonably new to this AV malarky.
    Read through the masses of info on the forums in these sections (amps/speakers etc) and you'll see the type of kit people are pairing up: there are countless "What will sound good with X amp, Y speaker or Z branded speaker?" - and often a host of replies.
    When kit within a suitable price range comes up in the classifieds, theres nothing wrong with asking for specific advice on those items in the right forum.
    i.e "just seen X in classifieds, for Y price, what do you think?"
    You'll likely get a feel for prices and equipment quickly this way, although be prepared (potentially) to miss some sales due to reply delays between the forums.
    On the classifieds however, be careful what you ask, as its the most heavily moderated forum. e.g Don't ask on the classifieds forum, "Is X piece of kit worth what Smurfin is asking?" on my for sale thread. It can get very messy (if you know what I mean). - so if you see that I'm selling some speakers in the classifieds, theres nothing wrong (in fact I'd encourage it) in asking in the speakers forum what people's opinions are.
    Theres a number of people I often PM when I'm looking to buy something to say "what do you think @ this price?" and I often get good advice back.
    Just my 2 penn'o worth:)
  14. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Not true. I have Eltax speakers that have survived 2 amp upgrades and still deliver quality sound. A matched set of Eltax will sound better than trying to mix and match used speakers. Just my opinion, but your ears will tell you what you like.:lesson: :)
  15. menalaus
    menalaus
    Apr 25, 2003
    338
    sleepy hollow
    +6
    hi mylo, i personally think there are better budget options than eltax available in the classifieds but each to there own. i do agree that a mix and match approach to speaker manufacturers is not a great idea, leading to tonal imbalance across the front sound stage, but i dont feel that this will be a big issue at the back.
  16. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Hello mate, totally agree about the rears I personally use Bose style bipolar cubes from cpc (not Bose style cost though). I have tried an Eltax package before and to be honest it worked well. With a copy of What Hifi you can get good prices on them from RS.
    I mistook your comment as anti RS/Eltax, no offence meant.
  17. menalaus
    menalaus
    Apr 25, 2003
    338
    sleepy hollow
    +6
    none taken mylo, i have no wish to side track this thread and the whole RS bashing has been done to death. what i would add though is that RS et al (online shops included) do have to sell what is in there shop and if its not what you came in for they will do there best to get you to spend your money on something else, regardless of whether its any good for your needs. so unless you know your stuff and are confident in your choice in the first place newbies (for want of a better description) can occasionaly be sold 'inappropriate' kit. this is i feel yet another good reason for people on a budget and/or new to all this, to use the knowledge and 2nd hand hardware available here.
    p.s you dont work for RS do you :D
  18. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    RS. never. I work on military avionics.:laugh: :smashin:
  19. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    726
    midlands
    +16
    well theres seems to be a matter of opinion several set ups will have to look around
  20. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    Guy wait, the Phillips mx980 home cinema is an interated sat sub system can't just upgrade the speakers.
    WHY?
    The main problems with replacing the satalites with better speakers are:
    1) The amplifier in the main unit has a preset/fixed crossover setting for controlling the mid and upper freqencies sent to the satalites.
    2) As this crossover is set quite high (approx 120hz), if other speakers were used as replacements for the satalites the results would not be very good, there would be no bass at all.
    3) The Amplifier is not rated for high wattage output or low ohm loads from its terminals this means standard hifi speakers would sound bad and run a serious risk of damage to the amplifier and speakers.
    You will need to get a proper AV receiver to power new speakers.
  21. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    726
    midlands
    +16
    micb3rd
    nice to know somebody knows about the mx980 like i said im very happy with it maybe cuz its my first one and not really compared it to anything else
    dont suppose you CAN tell me a answer to something i cant seem to fathom
    when setting the speaker sizes is it best to set the front to large or small i know this has something to do with the bass handling regarding frequencies but not to sure which you think would be best i consulted manuel but it dont help much
    also was looking at the denon 1803 amp
    and i seen some wharfdale 8.3 front and wharfdale centre and same surrounds at superfi which prob total my budget would these be ok for the amp my room is approx 13x13 perfect square
  22. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    726
    midlands
    +16
    www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1029
    THIS FOR CENTRE 89QUID
    THESE FOR FRONTS
    www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/727
    155 QUID
    and finally these for rears
    www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1443
    AT 55 QUID
    BUT CANT FIND A SUITABLE SUB
    would these speakers go ok with the 1803 amp or any suggestions on maybe a different amp or speaker package
    total budget maybe 600 quid and will this sound better than my current one which can be seen here
    www.techtronics.com/uk/shop/617-philips-mx980-av-system.html
  23. avanzato
    avanzato
    Jan 21, 2003
    1,881
    Norfolk
    +61
    The Wharfedale 'screen 3' pack is a cheaper way to buy those speakers.
    £270 at QED-uk
    It's an all diamond 8 package as it comes with Diamond 8.1 rear speakers instead of the Dipole/bipoles? you picked.
    For amps you could look at the Yamaha AX640SE (no tuner) which is the new version of my AX630SE and other people swear by their Marantz SR4300's. Oh and Onkyo too.
    ....and it will sound better than your Philips.
  24. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    Sorry I don't specificly know about the Phillips mx980, most all in one systems run high crossovers and the amps are not really up to power bigger speakers to decent volumes.
    In the end If you want to use new speakers a better amplifier like a Denon, or Yamaha, Marantz will give you much more flexability and sound a lot better.
    The Wharfedale diamonds are a good choice for new speakers.
