Speaker positioning?
Discussion in 'Home Cinema Speakers' started by Merritt, Apr 7, 2003.
  1. Merritt
    Merritt
    Feb 5, 2003
    263
    Hampshire
    Ok - so I now have a nice pair of Kef Q1s for my front left and right channels & the amp should be arriving tomorrow. Now to speaker positioning.....
    I've always believed that its best to have the front speakers as far apart as possible but there is 'guide' in the KEF box that suggests that the speakers should be at least 1m away from side walls in the room and at least 23cm from the back walls in the room. In my room - this now means that the speakers are approx 1.5m apart and 23cm away from the wall so they are only just wider than my plasma screen....
    Is this entirely necessary & what effects am I likely to introduce if I ignore this and move them further apart?
    Steve
  2. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    I believe that for normal stereo listening, further away and toed in slightly is better. But for HC closer and pointing straight forward.
    I can only really get my Q1s a few metres apart anyhow so just leave them there and slightly toed in all the time :)
    Sounds fine to me :)
    The speakers are around 70cm from the rear walls.
    Dave
  3. gilmore
    gilmore
    positioning closer to rear\side walls will increase bass output (possibly make it a bit too boomy) - positioning away from rear wall should add a bit more depth to the soundstage
    the q1s are front ported so close to rear wall shouldn't be too much of a problem for you
  4. severnsource
    severnsource
    Jan 19, 2003
    322
    +9
    I think there are two issues here, positioning for stereo effect, and positioning for sound quality.
    The norm for good stereo is for the listener to be at the apex of an equilateral triangle, i.e. you are as far from each speaker as the speakers are from each other. If the speakers are much further apart than this the image tends to collapse towards the speakers, giving a hole in the middle, if they are much closer together the image width is reduced.
    If the speakers are to close to a corner the sound quality tends to suffer, becoming coloured and less clear. I think this is what the KEF guidelines are refering to.
    However all these are just recommendations. Start with these and then move the speakers around 'til you find a position that suits your expectations of image size and colourations.
    Bill
  5. Merritt
    Merritt
    Feb 5, 2003
    263
    Hampshire
    Thanks guys - when my amp turns up, I will have a play!
    Steve
  6. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Just a small point to add - my Q1s don't seem to suffer from being close to a side wall (currently the left speaker is only about 15 cm from the wall).
    I have them about 11 feet apart toed in about 10 degrees.
  7. MrPumpkinHead
    MrPumpkinHead
    I currently use my Q1’s in a smallish room with only about 0.5 metres between side and rear walls.
    They sound fine to me, although bass below 80Hz is sent to the sub which probably helps.
    Don’t forget that you can also use the foam bungs in the front port if you find the speakers boomy close to the walls.
