N
neilc
I'm a little bit confused ... I'm in the process of converting my garage to a (small but dedicated) cinema room. The room size is 4m x 2.5m
I've been reading the various mags and have visited a few outlets, but even the same companies but different stores give different advice.
I'm torn between three speaker set-ups:-
1. M&K package (K7x3,K4x2,K5x2,MX125 MkII)
2. Mordaunt-Short 500THX
3. Crane Ocena
... to be honest the first two are winning. However, apart from the second being THX which are the better speaker, bearing in mind now that the first is twice the cost of the second, which in turn is twice the cost of the third.
Also, for Dolby 7.1, should the side and rear speakers be positioned at head height or at ceiling level ? ... I've been unable to find the info anywhere as to which is better.
Hope you can help.
3. Crane Ocena
Hope you can help.
