Speaker pop
Discussion in 'AV Receivers & Amplifiers' started by Curry Monster, Jun 9, 2003.
  1. Curry Monster
    Curry Monster
    I got the strangest pop from my HC setup yesterday when I played Joe Satriani's Live in San Francisco dvd. The pop from the speakers occurred exactly when the transition of two channel stereo (menu section) kicked into DD 5.1 for the film.
    I did notice it did not happen again if the audio track is selected for DD 5.1 first. This problem seems to specific to this dvd disc only as I have tried it out with other discs.
    Is this normal or something broke on the amp?
    My setup is Marantz SR6300 with MS Premiere speaker pack and Sony DVP725D.
    Cheers.
  2. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    Some amps are worse than others with "poping" when changing source, decode mode, etc. It's to do with the muting circuits. Has it just done it once ... or does it do it regularly? This could be a one off or a symptom of a more serious problem.
    Vikki
  3. Curry Monster
    Curry Monster
    I've only noticed the problem on the Satriani dvd. I've got a very large collection of discs and have not had a problem with them. Note the amp is about 2-3 months old. I think (fingers crossed) it just one of those things.
    Thanks,
    M.
  4. Vection
    Vection
    Mar 23, 2002
    129
    19
    Over there!
    I've had this with my arcam avr100. With some discs it will pop but with others it wont (I cant remeber specific titles). Anyhow, I've had it for over a year now and no probs yet.
    Is everything earthed properly?
  5. Chrissywis
    Chrissywis
    Jun 8, 2003
    146
    16
    London
    If the DVD doesn't conform to the proper audio specifications, you can get problems with splats on startup. There's something about needing X amount of silence before audio starts, I can't remember how much. My DVD of The Terminator puts an horrendous splat across the speakers once Play is selected from the menu.:mad:
