speaker "pop" when i change dvd menu ....?
Discussion in 'AV Receivers & Amplifiers' started by jackal2513, Aug 6, 2002.
  1. jackal2513
    jackal2513
    on my aego p5 system whenever i go to a menu or select a menu item on the dvd i get a very annoying & quite loud pop through all of the speakers. I did a quick search on teh net and it seems its something to do with the bitstream being interupted ... is there a way to get rid of it. My dvd player is the Toshiba 210.
    regards
