Speaker Placement?
Discussion in 'Home Cinema Speakers' started by Cheng, Jan 18, 2003.
  1. Cheng
    Cheng
    Dec 19, 2002
    389
    +7
    I recenly set up my new speakers, however the surround sound speakers are not behind me or even at the side of me! They are about 45 degress on the side depending on which side you're sitting...
    [​IMG]
    Will this really affect how it sounds, or is it really meant to be coming from behind you? I am trying to rig up a 6th speaker near the 1 seater though...
    Any suggestions?
    Thanks.
  2. coolposter
    coolposter
    I did a little adjustment. Give it a try and see if you like it.
      Size:
      15 KB
      111
  3. coolposter
    coolposter
    And this is what ITU recommends.
  4. Cheng
    Cheng
    Dec 19, 2002
    389
    +7
    Thanks for your reply...
    Wouldn't that seating look very odd? I mean, the one seater sticking out of no-where?
    Thanks anyway.
    What I'm trying to get at: would it really affect movies that much if it was infront?
