Speaker placement...
Discussion in 'Home Cinema Speakers' started by andy76, Dec 27, 2000.
  1. andy76
    andy76
    Currently 'only' stereo, I have my system set up in my bedroom.
    I have partitioned the room with a wall unit to make a 'room' about 6.5 foot by 14foot long.
    Speakers are on the shortest wall - and hence near to corners.
    I now have boomy bass - I know it is the corner positioning that is coursing it but can I do anything about it??
    Would a heavy material hung behind them help??
    Andrew
  2. Guest
    If your speakers have rear ports you could stick something in them, Cloth would be OK.
    B&W speakers supply a plug to stick in them if they are a bit too bassy.
  3. StuartBooth
    StuartBooth
    I got some round foam 'bungs' with my speakers. There's a hole round the back of the same size, and from comments in this forum I tried inserting said bungs into the back of the speakers.
    I was amazed at how much solidity from the bass that I lost. A quite remarkable difference.
    My old Mission 752s have a single hole in the front I think, although I rarely took the grills off so I'm going from a faint memory here.
    Definitely worth a go if your speakers fit a similar description.
    Stuart Booth
    Somewhere in Buckinghamshire, England, UK
  4. andy76
    andy76
    Thanks for the replies.
    Sorry.
    My speakers are B&W 602 and have no rear facing ports.
    Any other ideas?
    Andrew
  5. Jamestuk
    Jamestuk
    Nov 5, 2007
    411
    Ingolstadt, De
    +23
    try it! duck tape a cushion behind each speaker or to the sides, or just generally anywhere really- experiment see if it changes owt! If it works go buy something more aesthetically acceptable.
  6. paulst10
    paulst10
    Dec 16, 2004
    12,435
    Essex
    +1,838
    :rotfl: You may not get much of a responce .. this thread was started 8 years ago :D
