Speaker placement
Discussion in 'Home Cinema Speakers' started by mike.griff77, May 10, 2005.
  1. mike.griff77
    mike.griff77
    Hi guys,
    This is the probably one of the most frequently asked questions in the forum but here goes, I hope you can help.
    Ive got a Pioneer home theatre system, not a major expensive thing but it does the job. I have a fairly big lounge but the TV is limited to where it can be, and unfortunately it has to go in the Corner. How should I position the surround speakers? Its a 5.1 setup with a 32" toshiba tv. The other issue is with the front speakers, obviously they will not be flat mounted to the wall so is it best to use stands or sit them on the floor?
    I appreciate any help!
    Mike
