Speaker Placement
Discussion in 'Home Cinema Building DIY' started by Dancook, Apr 7, 2017.
  1. Dancook
    Dancook
    Feb 15, 2007
    15,239
    +5,928
    I think I'm finally narrowing down what I want, this is all to scale, except the speakers are IN wall not on wall and don't stick out quite like they do in diagram.
    7.8m x 4.5m room
    120inch wide 2.35:1 screen
    Kef CI 5160RL THX x 3 (front)
    Kef CI 200RR THX x 4 (atmos ceiling)
    Kef CI 200QL x 4 (surround)
    Considering the shape of the room, and that speakers should ideally be ear height where possible, I'm not sure there's much scope for me to go wrong. Maybe the L/R are too close to the side wall?
    I'd appreciate any suggestions for improvements
    speaker_placement_1.jpg speaker_placement_2.jpg speaker_placement_3.jpg speaker_placement_4.jpg
  2. Kev Greenhalgh
    Kev Greenhalgh
    May 3, 2012
    588
    5
    25
    96
    Manchester
    +741
    This is more of an observation than an "expert" opinion ;), but if you could bring the F L+R cabs in by 6", then toe them in slightly. Or would that narrow the soundfield too much?
  3. Harkon321
    Harkon321
    Jun 6, 2012
    1,556
    +338
    Looks great. I'm just really jealous of the space you've got.
    • Thanks Thanks x 1
    • Agree Agree x 1
    • List
  4. Dancook
    Dancook
    Feb 15, 2007
    15,239
    +5,928
    Perhaps!
    Whenever I read about these speakers, they don't seem to be very directional anyway.
    The marketing on the 200QL says
    "Featuring KEF's sophisticated 'sit anywhere' Uni-Q driver array, which places the tweeter in the acoustic centre of the bass/midrange cone, this allows both the tweeter and woofer to act as a single point source that disperses the sound widely and evenly throughout the room."
  5. Kev Greenhalgh
    Kev Greenhalgh
    May 3, 2012
    588
    5
    25
    96
    Manchester
    +741
    Just been reading through the specs for the KEFs and toeing in isn't necessary, or they've been designed without that in mind. They seem to be much less "fussy" in relation to other conventional loudspeakers. :)
    If they do have a wide soundfield, then bringing them in closer to the screen will reduce acoustic rebound from the side walls. The only problem is once they're in, they're in for good.
  6. Dancook
    Dancook
    Feb 15, 2007
    15,239
    +5,928
    I've gone with the current arrangement to avoid spending money on a larger acoustic transparent screen.
    But the screen away from the wall, so blocking some diagonal sound I guess, how much further from the wall it is unknown until I know how much ceiling height there is in the new roof space.
    Do you think the screen not being acoustic will present a problem for this? maybe as long as they are a couple of inches to the side.. it'll not be present a noticeable problem.
  7. Kev Greenhalgh
    Kev Greenhalgh
    May 3, 2012
    588
    5
    25
    96
    Manchester
    +741
    I don't think it'll make a difference at all. There's certainly more qualified AVF gang out there to offer a definitive answer though.
    Just so I can have a nosey around the interwebs, which screen have you decided on?
  8. Dancook
    Dancook
    Feb 15, 2007
    15,239
    +5,928
    Not yet decided on, originally was looking at acoustic transparent screens - but need to bring the cost of the entire setup down a little - having a trap door isn't cheap, but I'm still balancing all the equipment costs.
    Having CI-3160 surrounds was a luxury which I had to change my mind on :D and now researching between Arcam AVR550 vs Anthem MRX1120
  9. Kev Greenhalgh
    Kev Greenhalgh
    May 3, 2012
    588
    5
    25
    96
    Manchester
    +741
  10. Dancook
    Dancook
    Feb 15, 2007
    15,239
    +5,928
