speaker placement in Home Cinema
Discussion in 'Home Cinema Speakers' started by PC_112, Apr 22, 2005.
  1. PC_112
    PC_112
    Feb 11, 2005
    229
    +3
    Hello,
    Whats the best way to place 5 small sattelite speakers (e.g. Gallo micro) in a small room (2m x 3m)?
    The room doesn't have wall on the right side, and the way it is arranged it is not possible to put the sats in a square arangment (except if I put them very high (2.5m).
    the way it will look better is if I put the center right bellow the TV, the left and right speakers right next to the TV (42" plasma), and I can place the rear sats anywhere.
    However, some people told me that this way the left and right speakers will be very near the center (less than 50cm), and I will loose the whole cinema effect. If this true?
    Are there small sat speakers that can work better in this arrangment than others?
  2. richard76
    richard76
