Speaker Placement Help Please
Discussion in 'Home Cinema Speakers' started by betamac, May 25, 2002.
  1. betamac
    betamac
    Right now i have a Sony 1070 AMP and 5.1 speaker setup using Mission Speakers as follows
    Fronts: Mission M73
    Rear: Mission M72
    Centre: Mission M7C1
    Subwoofer: Kef PSW1000
    I would like to get some Centre rear speakers and the matching set would be the Mission M7DS Best Price i seen is £128.00 i presume thats for a pair Anyone seen em cheaper?>
    anyway where would be the perfect place for them right now i have the surround rears on stands slightly behind my listening position, if i put the Centre rears on the wall flush with the ceiling they would be level with the surround rears, but i could move the surround rears slightly forward (level with listening position) what do you guys think?
  2. Jase
    Jase
    Mar 16, 2001
    10,721
    United Kingdom
    +2,487
    The rear centre speaker/s need to be a few feet, at least, behind the normal surround speakers.
    I would bring the M72´s forward and have them pointing in at your listening position. Leaving you some space between them and the rear centres.
    You could also try the M72´s as the rear centres (on the stands behind you) and put the M7DS at either side of your position, this would probably give you better results for movies.
    Worth a try anyway.
    cheers
