Speaker Placement for 'L' Shaped room
Discussion in 'Home Cinema Speakers' started by amrishraje, Nov 28, 2010.
  1. amrishraje
    amrishraje
    Nov 28, 2010
    Hi Guys,
    I need some help determining the correct placement of my Klipsch 5.1 speakers in my living room. I live in an apartment :( and do not have much control over placement of my TV and Sofa apart from putting them in the predesignated area. I've attached my room layout. Any help with placement of speakers is highly appreciated. :lease:
    Thanks...
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    I would put the fronts either side of the TV within the sides of the wall i.e. just about on the width of the sofa. The centre would then go under the TV. The rears I would put just outside the width of the sofa and the sub I would probably put in the top right corner just across from the TV.
  3. everett_psycho
    everett_psycho
    Nov 20, 2009
    8,096
    Christchurch NZ
    +2,620
    I'd just treat it as if it was a room that stopped about a foot to the left of the sofa, so the fronts and centre by the TV and surrounds either side of the couch like you would if it was a normal shaped room
