speaker package or pick and mix?
Discussion in 'Home Cinema Speakers' started by mobily, Jan 18, 2004.
  1. mobily
    mobily
    Dec 30, 2003
    504
    Plymouth
    +3
    Hello all,
    Would an av and music setup using the pre outs of the av amp to the hifi amp be better suited to a speaker package, or would it be better to buy a pair of really strong fronts for the music and then add the centre, rears and sub after?
    Can speakers designed for music provide good sound required for movies?
    Cheers,
    James :)
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    it depends what you want...... if music is your main concern, get the better main speakers. But you need to be aware that it will likely sound mismatched to a weedies surround setup. The centre most likely just wont be able to image well enough to contend with the fronts.
    But i would also say that music speakers can definitely contend. I use a setup of 6 identical 0…7music type speakers and it continues to keep me smiling.
    ad
