Speaker Output
Discussion in 'Home Cinema Speakers' started by AdyCool, Feb 28, 2005.
  1. AdyCool
    AdyCool
    Is it possible to connect an amplifier or a 5.1 sound system to a standard TV so that you can listen to normal terrestrial TV through the extra speakers?
    Thanks :thumbsup:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,639
    +4,906
    Not unless it has sockets for extension speakers on the TV.
    Most televisions have a pair of audio output sockets but these only output a low level signal that needs to be amplified with an external amplifier.
  3. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    My toshiba tv has 4 speaker outputs and the tv acts as the centre (and pseudo sub).
    Not a patch on HC though.
  4. Roohster
    Roohster
    Jul 1, 2004
    4,712
    7
    Derbyshire
    +5,806
    I think Ady means can you connect the Tv's output to an amplifier, in which case the answer is yes, if your tv has an audio output.
  5. superpixel
    superpixel
    If theres no dedicated audio phono output, then you can use the Scart output (as should be on all TVs for recording to VCR etc) - a Scart to Audio lead will do the trick. It may even be better quality, as quite often the audio outputs on TVs aren't fixed level and you set the volume on the TV.
    Enjoy those rich, warm NICAM broadcasts - and old Pro Logic still sounds good you know :D
  6. AdyCool
    AdyCool
    Haha, thanks, so if i used a SCART audio output- would this mean that the audio output will still work for other things like DVD player, VCR or games consoles?
  7. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Yes!
    For instance I don't use the TV speakers, only the hifi, it gives TV watching another dimension...
