Speaker matching
Discussion in 'Home Cinema Speakers' started by Big Jim, Dec 20, 2000.
  1. Big Jim
    Big Jim
    I am in the (painful) process of deciding on speakers for my first HC system.
    As far as I understand, the main L/R's and the centre should be tonally matched (ie speakers from the same range), but what about the rears? should they be matched, or is it just a case of whatever comes to hand?
    My current plan is buy over a period of time, with a pair of floorstanders coming first to get things going, with a matching centre arriving as and when. Finally proper rears will replace a nasty pair of midi system speakers that are lying around.
    My current cunning plan/short list is one of the following:
    Mission 773e with a 77c1
    Yamaha NS-200 and NS-C200
    Mission m73 and m7c
    any thoughts on those - or other suggestions?
    For rears I'm stuck, but they have to be wallmountable
    cheers
    Jim
    [This message has been edited by Big Jim (edited 20-12-2000).]
  2. Big Jim
    Big Jim
    I forgot to say - the speakers are being used with a Yammy DSP-A5, Marantz CD-53 and a Homecinema PC...
    Assuming Letsbebent.com ever get round to delivering the A5 of course - its only 2 months since I ordered it... [​IMG]
    Jim
  3. Guest
    Ideally match all 5; if you can't, for budgetary or aesthetic reasons, then make sure that at least the front three are tonally matched.
  4. Big Jim
    Big Jim
    The speakers will be going into a small and distinctly non dedicated living room (6m x 3m ish room, with 2.5m x3m space for sitting/telly/dvds/dreamcast - The joys of living in a small 1 bed London maisonette.
    My 'TV' sofa is hard up against the wall so rears will have to be wall mounted
    For rears I was going to go with the matching mission ones, but I'm a bit stuck about what to put with the Yams. (assuming I go for them after I've had a listen to all of the above)
    Any thoughts on the relative merits of bi/di-poles and monoples for use as rears? (especially when wall mounted above the listener on the rear wall)
    Jim
