speaker location
Discussion in 'Home Cinema Buying & Building' started by mahir123, Jan 10, 2008.
  1. mahir123
    mahir123
    Nov 23, 2007
    hi everyone!
    i was wondering if anyone could tell me where the best place to keep the speakers in my 5.1 system, the picture is my room, the red line is the tv, it is in the corner on a stand, the blue lines are my l shaped sofa. i cannot move the tv due to a fireplace.
    thanks alot.
    Mahir:thumbsup:
  2. jezzer256
    jezzer256
    Oct 18, 2006
    1,879
    63
    Sussex
    +164
    Can you mount speakers on the walls? If so, I'd put the 2 front speakers on the walls either side of the TV, and the 2 back speakers on the 2 walls that the sofa backs on to.
    The centre could go below or above the TV, and it doesn't really matter where you put the sub - by the side of the TV on the floor, or by the side of the sofa; either would sound alright.
    Jez
  3. Robsk1
    Robsk1
    Sep 24, 2007
    1,125
    Exeter
    +122
    I'd agree with Jez. As the placing of your sofa and TV isn't in the typical 'best location' then you need to adapt.
    I have a similar sitting area but it's down the lounge end of the lounge / dining room and it has a 3 and 2 seater at right angles. I wall mount the satelites (blue elipses on attached file) and the sub is to the left of the 3 seater (and the centre is below the plasma).
    My wife and i only use the 3 seater when watching films and if we have guests i'll swivel the speakers slightly to give a better 'for all' sound.
    HTH.
    Rob.
  4. @@@@
    Nov 26, 2007
    155
    +8
    Forgive for asking why will the picture the forum member enclosed show as a thumbnail picture like we used to have what has changed.
  5. Robsk1
    Robsk1
    Sep 24, 2007
    1,125
    Exeter
    +122
    Mine was a JPG and the OP had attached a BMP file. Would this provoke the difference?
  6. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,255
    +4,195
    Correct me if I am wrong, but the obvious solution seems to be -
    - one Front on either side of the TV,
    - one rear on either side of the Sofa sectional,
    - the center in front of or below the TV,
    - the sub can be placed pretty much anywhere.
    If I'm luck, there will be an attached image.
    Steve
  7. Robsk1
    Robsk1
    Sep 24, 2007
    1,125
    Exeter
    +122
    You also get my vote for best diagram in this thread!!
  8. recruit
    recruit
    moved to the audio calibration forum.
