Question Speaker internal crossover specification
Discussion in 'Home Cinema Speakers' started by kalniel, Aug 18, 2016.
  1. kalniel
    kalniel
    Dec 19, 2011
    10
    Hi!
    I'm comparing Monitor Audio Bronze 5 and 6, and quite obviously I know the 6 with its bigger and additional cones will push more air for bass. But I'm interested how this is depicted in the specifications:
    Bronze 5:
    LF: -6dB @ 600Hz
    MF/HF: 2.8kHz
    Bronze 6:
    LF: -6dB @ 150Hz
    MF/HF: 2.5kHz
    I'm used to crossover notation with respect to a subwoofer, but I'm less clear how it's used within a floorstander like these.
    Is it saying that in the case of the 5, frequencies are split with the bass-cone handling 600Hz and below, mid-cone 600-2800Hz, and tweater 2800Hz+? Or as these are 2.5 way is the split more simply 600Hz and below to the bass, while 600+ go to mid+tweater together?
    On the other-hand, the 6 has a 1" larger mid-cone, so they push 150+Hz to the mid, and sub 150Hz goes to the dual bass-cones?
    It seems either way, the bass cones have a 6dB penalty, but on the 6 this only affects the sub 150Hz region while on the 5s this is going to affect everything below 600Hz?
    Yes, I should probably just get out and test them both (added caveat is the NR 1506 AMP is borderline powerful enough for the 6s, only [email protected] Ohms), or save up and buy a sub to go with the 5s?
  2. AudioVisualOnline
    AudioVisualOnline
    Well-known Member AVForums Sponsor
    Dec 4, 2008
    1,683
    116
    5 The Sidings, Bacup, Lancs, OL13 9RW
    +792
    The -6 indication is specifying the crossover slope, not attenuation to a driver specifically, or its entire working range. The crossover doesnt just brick wall stop frequencies at a set point, they are gradually attenuated so the drivers blend together during operation, and this is what this figure typically tells us. Its actually impossible to give a set crossover frequency because of this gradual attenuation, the speaker still produces output below or above a stated crossover frequency, its just that it drops off, so the LF: -6dB @ 600Hz statement is telling us the LF driver is 6db down by the time its producing frequencies as high as 600Hz.
  3. kalniel
    kalniel
    Dec 19, 2011
    10
    Oh thanks! That makes more sense.
