Speaker help!
ThomasF24
Hello everyone!
After a long time deciding upon a brand new wonderful TV (which I was about to go crazy trying to decide), I've landed in the same pot again it seems, choosing sound for it!
We sit 3 m from the TV. As we're from Scandinavia, prices doesn't always match with UK / Europe prices, so these are my current options - and feel free to add if someone has better ideas!
Main use is watching movies. I can't choose between floor standing or lifted bookshelf ones, but they have to stand on the floor nonetheless.
Dali Spektor 6 (only one's I can actually hear in a store, sounds good)
Monitor Bronze 5
Klipsch R-620F or R-26F
Or bookshelf Dali Oberon or Klipsch RM
All are inside the same price group here.
Any input on what route to go?
We'll start with two speakers, get a sub, but probably that's it for now and then a center later maybe.
MaryWhitehouse
Hi. What’s powering the speakers?
MaryWhitehouse
Can you get any of those speakers so you can return them if they don’t work in your room? Same for amps.
ThomasF24
As far as I know only the Dali, the rest are from webshops, and that's usually very difficult if the product has been used :/
Edit: the place I can get the MAs from says one has to return them yourself (3 hours drive) in case one doesn't like them 😅
MaryWhitehouse
Lol then I'd start with the Dali's.
MaryWhitehouse
I don't know about the Klipsch but both of the other's should be good.
Rehan Essani
Hello everyone!
Monitor Bronze 5
Hey! i suggest you to go for Yamaha RX-V485 thsi is best for a room based system or for just small enjoyment
Similar threads
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
