Speaker help
R
ruffrider
Ive got a kef thx ref speakers and servo 15 sub .. love em to bits ... but there a bit big in my 5x4 yard room so im considering going over to m&k ..question is are these little m&k speakers as good as my beastly kefs .. ???
all help apprecaited :)
ta
al :)
It depends which M&K range you are talking about. I think that you may find the K range not as good as your existing speakers but above that level they really do start to sing.
thanx for your reply ;)
Ive been to sevenoaks today and they told me the same thing that mine was better than the k range but they have a new xenon range which was due in anytime which was very close .
I was maybe thinking of maybe selling mine and trying to buy used m& k set off here for my size room and ideally id like speakers to be more compact size have you got any suggestions ?
thanx
al :)
the chap form sevenoaks suggested that my speakers were far too big for my room size and drowning out the sound ?? any suggestions about this ??
thanx
If you want M&K's that are comfortably going to outperform the Kef THX package then look towards the S150THX package. I used to have the Kef's and changed to these as fronts with S85's as rears and they are superior in pretty much all aspects. :)
Thanx for the reply jase ,,
Unfortunately i cant really afford that at the moment .. wife kids house car :( :( .. not much money to play with ..
To be honest im only really thinking of the possibility of change because of the wifes moaning :( ,,
I dont think im going to get something as good to be honest without spending loads of money maybe i should set my sights lower ?? maybe i should be looking for a good sounding setup over a great one ?
now im totally confused :confused:
any thoughts are apprecaited
al :)
The answer is obvious to me when you consider that you love your speakers to bits and your wife is moaning about them.
how about 3 X M&K S-85's across the front?i heard them and they really are very pleasing speakers, to hear not to look at unfortuantely, but yeah small, compact and should be able to keep up/surpass performance wise.
fred
p.s hows the pj doing mate?
ta
al :)
Have some M&K LCR55;s for sale right now. Got three for sale and only looking for £500 :suicide:
Main post is in the classifieds,
Cheers.
Thanx for the replies :)
fred the pj is beutiful ... love it ....
thats a good idea ill keep sn eye out for the s85s but its 5 id want really
Hey Gareth ive seen your post aswell and ... they look ok but ill keep on the back burner for now as its a full set im after really with slightly better spec ...
but thanks anyway :)
al
After much deliberation .. ive decided to keep my astounding speakers ... ive just sat here and was blown away again ..
Its took me years of upgrading to get here .. and im happy :)
But ive had to give in to the mrs a bit and get rid of me big fat black wires all over the show ... but its worth it :)
thanx for all your thoughts :)
al
The BIG PROBLEM With Your Home AV System EXPLAINED
Back
