Speaker Help - Centre + Front R&L
Discussion in 'Home Cinema Speakers' started by jakspaoo1, Jun 23, 2015.
  1. jakspaoo1
    jakspaoo1
    May 25, 2008
    85
    I'm in the process of upgrading my amp etc and have just bought a Yamaha RX-V677 so am looking to start with a centre and fronts.
    Budget is £250-£300, the Q-Acoustics have caught my eye but will they go with the amp?....I have rears at present and will change those shortly.
    All help and recommendations appreciated :)
  2. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    Which QA speakers are you looking at. QA and Yamaha should pair well together so no issues there.
    Others speakers to look at would be the Monitor Audio BX range (or Bronze) or the Focal 700 series.
  3. jakspaoo1
    jakspaoo1
    May 25, 2008
    85
    2010i or 2020i at a push
  4. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    go for the 2020i
  5. jakspaoo1
    jakspaoo1
    May 25, 2008
    85
    Thanks, it was either that or some pre-owned Kef Eggs.
