Speaker Height?
Discussion in 'Home Cinema Speakers' started by ldoodle, Jun 13, 2003.
  1. ldoodle
    ldoodle
    What's the recommended (if any) height to put the front l/r's and the surround speakers?
    I was thinking of putting them at roughly 1.4 metres off the floor. Is this a good/bad idea? Or should I put the surrounds higher/lower than the front l/r's?
    Thanks/...
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Tweeter at ear level when sitting is the normal height IIRC
  3. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Agree tweeters at ear level, rears at 1 ft above ear.
    Try to get centre in line with L & R
  4. Zone
    Zone
    Jun 24, 2001
    6,747
    Barnsley
    +2,442
    Don't agree, definately depends what type of speaker you are using, Direct/Bipole/Dipole..
    Also room acoustics and placement make a huge difference, suggest you take your time and play about with different positions until you get a sound you are happy with.
  5. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    ... particularly if you want to have multi-channel music
  6. ldoodle
    ldoodle
    How would I know if i'm using Direct/Bipole/Dipole speakers?
  7. S H A D O
    S H A D O
    Mar 16, 2001
    10,445
    United Kingdom
    +1,825
    Do you have the speaker make and model numbers?
  8. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    If you are still using your Sony HTK 215 all in one system, the speakers will be direct radiating, as I think are most speakers in all in one units
