Speaker Grills
Discussion in 'Home Cinema Speakers' started by Queen of Hearts, Mar 16, 2003.
  1. Queen of Hearts
    Queen of Hearts
    Just out of interest do you leave yours on or have you removed them!
    Does it affect the sound any?
    Mine by the way are well and truly naked just the way nature intended :D
  2. nathan_silly
    nathan_silly
    Leave em on, expensive mistake if I pierce em! Doubt it makes much difference, if any.
    My standmounters do look fab w/o the grille- real wood veneer in red cherry. Luvly!:D
  3. Dronach
    Dronach
    Jul 14, 2002
    9
    Shropshire
    Mine are left on. It shouldn't make any difference to the sound - something like "acoustically transparent" is used to describe the material used.
  4. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    Been messing about comparing a lot of 44kHz vs. 96kHz vs. 192kHz upsampled/native material recently. At higher resolutions is reasonably obvious with certain excerpts that the grilles on these speakers (B&W 600 s3) are not totally transparent. It is most apparent at low levels (obviously). I leave them off apart from when we're knockin' back the beers. :)
    I'm sure most higher-end/less image-centric kit does not have the same problem.
    MuFu.
    Edit - sp.
  5. Gryphon
    Gryphon
    Budget speakers might sound better with the grills off, think they use cheap cloth so the sound could be affected.
    I prefer the look of mine with the grills off, makes them look more expensive too. :)
    y=x3? That's odd. :confused:
  6. Cheshire Cat
    Cheshire Cat
    Acoustically transparent cloth is all well and good but what about the solid mesh of plastic that the cloth is fastened too? Surely this abundance of plastic is not acoustically transparent as well :rolleyes:. That said, I leave mine on because I can't get the damn things off :(.
  7. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    Well most plastic frames have an oraphice larger than the dispersion envelope of the HF driver and porting for low frequencies that supposedly doesn't interfere due to wavelength considerations. I think the cloth itself is the problem in most cases.
    MuFu.
  8. uncle eric
    uncle eric
    In general, there is no grill like no grill.
    However, some grills actually alter sonic character by design rather than accident.
  9. uncle eric
    uncle eric
    At the "No Grill" shop
  10. Queen of Hearts
    Queen of Hearts
    I agree ;)
    God intended the speaker to be clearly seen!
    There is surely no compromise :devil:
    I like you Uncle Eric, has anyone ever told you your avatar looks like Peter Cushin? Very dishy :kisses:
  11. nathan_silly
    nathan_silly
    I've gotten bacon and sausages all over my speakers- so much for this grille help! :D
  12. Chivalry
    Chivalry
    Oct 29, 2002
    272
    UK leicester
    +31
    all my grills are packed away neatly in a box in the attic :0) (how else can i lei my speakers on their backs and place a football on the large driver and watch it bounce about in time to the music?) jk... hehe
  13. EvilMudge
    EvilMudge
    Perhaps you should watch Howard Stern's Private Parts for a better use for a speaker with the grill off.:devil:
  14. Banni
    Banni
    Grills make a reasonable child protection system. I can clean the cloth easier then the woven kevlar. :D
    I try to :lesson: my daughter not to touch them, but hey, she's only 1.
    Sometimes I take them off in the evening, like em better that way.
  15. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    99.9% my grills stay on mainly for dust protection for the woofer and tweeter.
  16. NicolasB
    NicolasB
    Oct 3, 2002
    5,875
    Emily's Shop
    +566
    I recall that Uncle Eric's M&K 2510P speakers sounded perceptibly better with the grills off; at £1400 per speaker these are not exactly budget.
  17. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    Before my current B&W 805s,I ran a stereo system with Linn Keltiks triamped via Krells.....these were definitely not budget speakers and definitely sound better minus the covers(even Linn would agree with that).
    Certainly most,if not all of the speakers I've used/listened to incl things like the Wilson System V do sound better without the covers in place.
    Uncle eric does have a good point that some are better with the grills in place,esp some of the brasher AV offerings.
  18. Aloysius Smith
    Aloysius Smith
    I would suggest if you have a large extended family such as I have with lots of little ones running around and getting themselves into mischief, then leave the grills on, they are bland and very uninteresting to prying fingers and other sharp objects :nono:
    Take the grills off at your peril :eek:
  19. tomson
    tomson
    Jul 19, 2000
    1,918
    Berk'amsted
    +187
    Mine stay on ever since my cat sank his claws into the bass driver :mad:
    It was one of those slo-mo moments
  20. Wicked Wych
    Wicked Wych
    Ouch :eek:
    I did have a similar experience when my little one decided to push my lovely solid silver parker pen through the driver of one of my (then) Tannoy floorstanders :mad:
    Thats kids for you :rolleyes:
    Grills on now :smoke:
  21. Hobgoblin
    Hobgoblin
    Mine don't have grilles so the question is academic
  22. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Well, you say that but mine came without grilles and yet I had to make some up to protect them from (mainly) my one year old.
    Matt.
  23. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
    My Dynaudios have mounting points for the grills on the back of each 'speaker. I think that's a pretty good indication that Dynaudio prefer them off. I know I do.
    D.
  24. Circle Master
    Circle Master
    Mar 19, 2003
    39
    +5
    I leave mine off, main reason being to ensure even colouring of the wood as it darkens with age.
  25. Hobgoblin
    Hobgoblin
    That's a very valid reason if you live in a South facing house as two tone wood finishes will be that much harder to sell
  26. Dazed
    Dazed
    Anybody run their Gallo NM's w/o the "grills"? The material used for them is surely not acoustically transparent being very stiff. I can't get them off or even rotate them, in order to line up the AG logo.
    I too probably can't afford to have them "off" with a one year old running around - although she doesn't actually seem that inclined to play with my speakers/other gear. Remote controls and phones are more her kind of thing.
  27. Wicked Wych
    Wicked Wych
    The thought of one of the kids innocently attacking one of my speakers is just too much to bear, on for me :devil:
  28. Dronach
    Dronach
    Jul 14, 2002
    9
    Shropshire
    Just to say you can run the Gallo's without the grill. The way I found to do this was to move furniture around for my dear wife and have to rearrange the speakers, wires off etc and then when you're not looking they roll off and fall on the floor. The grills pop out really easily at this point. When I wired everything back up to see if the speaker still worked (with shaking hands) I didn't really care what it sounded like just that a sound came out. And then I put the grill back on. Luckily those Gallos are robust little beastie balls.:clap:
