R RobsterD Established Member Joined Dec 11, 2000 Messages 891 Reaction score 12 Points 189 Location Southampton Feb 20, 2003 #1 Hi Chaps What's the best glue for attaching grille cloth to a wooden(mdf) frame. Cheers Rob
N nathan_silly Guest Feb 20, 2003 #2 I would think Copydex should be OK. Never use cyano!! (fizzle, dissolve!)
R RobsterD Established Member Joined Dec 11, 2000 Messages 891 Reaction score 12 Points 189 Location Southampton Feb 23, 2003 #3 Cheers M8 that worked,doin the angles was a real pain !
O OBI-1 Guest Feb 28, 2003 #4 Does anyone know where can you buy acoustically transparent cloth? OBI-1
R RobsterD Established Member Joined Dec 11, 2000 Messages 891 Reaction score 12 Points 189 Location Southampton Feb 28, 2003 #5 I bought mine from Falcon Acoustics http://www.falcon-acoustics.co.uk/ Rob
