Speaker foam repair
Discussion in 'Hi-Fi Stereo Speakers' started by yinujim, Jul 15, 2018.
Tags:
  1. yinujim
    yinujim
    Jul 7, 2006
    1,097
    East London
    +52
    Can this speaker be repaired? Its used in a bass box and its a odd 4.5 inch size 2 OHM and 40 watts
  2. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,626
    +4,308
    Assuming it is a standard size, then likely it can be replaced. Foam Surround Rings are notorious for disintegrating, so there are speaker repair services that can replace the Foam Rings, and if you can figure out which ones you need, you can just buy the Foam Rings and repair them yourself ... assuming you are reasonably handy and have a good dose of common sense.
    Here is a video of the process for replacing the Foam Ring.
    How to refoam a speaker
    Though there are several places available that will repair the speaker for you and usually at a pretty reasonable price. I believe Wilmslow Audio does basic Speaker Repair -
    Speaker Repair, Speaker Kits, Loudspeaker Repair, Kits and Drive Units, Subwoofer Amplifier Kit
    Steve/bluewizard
  3. noiseboy72
    noiseboy72
    Apr 24, 2011
    6,268
    +1,888
    Yep, have a look on Ebay. Kits for JBL 4.5" speakers should work, but at that size, it can be a little fiddly.
