silvermilnec
Established Member
Hi wonder if someone can advise, my set up is in the Kitchen.
I've had a new kitchen fitted and have put a Squeezbox classic connected to a small old Oblisk amp on the top of my kitchen units feeding a pair of q acoustic 1010i.
It sounds as good as it's going to from the top of kitchen units BUT i'm getting feedback in the form of a speaker cracking now and again.
I've got a double plug socket above the units 1 is used for the low voltage lights the other ive put a small extension to power the classic and the amp. All the cables are running close to each other on top of the units.
Which cable is the most obvious cause (i dont get any other feedback) just the odd crack!
Speaker cable
interconnect
power
Speaker cable
interconnect
power
