Speaker fabric in door panels ???
Discussion in 'Home Cinema Building DIY' started by Gojira, Jul 25, 2002.
  1. Gojira
    Gojira
    Jul 13, 2002
    19
    Whilst messing around (drunk) with one of my speaker covers, I discovered that I could control my tv through the fabric.
    Would this then provide a suitably transparent material to use in the door panels of a cabinet I'm about to build?
    Damn site cheaper that mdf trellis!:D
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    It is a very good material to use since, as well as allowing IR codes through it also allows heat to escape.
    It's very commonly used in install cabinets.
  3. Gojira
    Gojira
    Jul 13, 2002
    19
    Cool. Thanks Richard.
  4. Amelia
    Amelia
    I am going down this path also. I really like the idea of having all the AV equipment hidden away :D
    Best Regards
    Amelia
  5. UrbanT
    UrbanT
    Jan 6, 2002
    13,293
    Aldershot, Hants
    +3,037
    It does work very well, and the missus loves it because it hides all the gear.
    Heres a pic of the cabinet built by my dad. Originally we were going to use frosted glass until a picture of an Arca made cabinet gave me the idea to use speaker material. Its very cheap from Maplin and works great
    [​IMG]
    Unfortunately my dad has passed away since so this is a nice reminder of how talented he was :)
  6. Amelia
    Amelia
    WOW that is AWESOME
    I have started work on mine, it should be complete soon. I am also incorporating a TV lift system in the unit (to make the TV disappear they the Projector is on).
    Regards
    Amelia
  7. Guest
    that is a really nice build, what wood is it and is that the centre between the two doors?
  8. UrbanT
    UrbanT
    Jan 6, 2002
    13,293
    Aldershot, Hants
    +3,037
    Thank James,
    The main wood is oak veneer, with the door frames being made from white oak. It was finished with a light oil, ie, no varnish. To be honest, the pic doesn't do it justice. Its a very simple design that works well.
    You are correct, the middle part is indeed the centre speaker (a B&W LCR60). The unit was housing a Denon A1SE, Tosh 900e, Sky and video and still has room for more bits :)
