speaker expert: IMF, B&W speakers?
Discussion in 'Home Cinema Speakers' started by chocolatebelt, Jan 8, 2012.
  1. chocolatebelt
    chocolatebelt
    Dec 31, 2011
    7
    Hello all,
    I have two sets of old speakers from my parents and am wondering if they're worth reusing and which ones I should take out of the two? I want to hook up an old grammophone using a newer (10 years old) sony amp. Or an old braun amp. I don't know anything about audio equipment...
    See below:
    IMF:
    [​IMG]
    B&W:
    [​IMG]
  2. PSM1
    PSM1
    Dec 20, 2008
    26,267
    +5,423
    I would be tempted to keep the B&W speakers. However since you have all the equipment try each combination and then keep the one that sounds best to you.
  3. Member 569079
    Member 569079
    Nov 2, 2011
    119
    Hereford
    +12
    The IMF floorstanding speakers are likely to have a deeper bass extension than the B&W's, so it will also depend upon your room size and music taste as to which suits best.
