Speaker emergency
Discussion in 'Home Cinema Speakers' started by Len, Dec 28, 2000.
  1. Len
    Len
    Have I blown my speakers? My two year old turned up the volume on my amp to full blast. Sony db930 ... and now one of my Mission 782's has developed a fuzzy sound to it. Any advice please?
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,253
    71
    Colchester
    +44
    Don't Mission have a 5 year guarantee that you can wangle your way through?
    Sounds like a blown woofer anyway, so should be covered.
    Be truthfull-ish.......
    Try swapping the speakers around to see if the fault stays with the suspect speaker. Then you'll know if it's amp or speaker or just a dubious (coincidental) connection.
    Douch!!......Wot's da madder, da CIA got you pushing too many penzils?
    Work: www.hughes-tv.co.uk
    [This message has been edited by General Skanky (edited 29-12-2000).]
