speaker distance
Discussion in 'Home Cinema Speakers' started by jason t, Jan 14, 2005.
  1. jason t
    jason t
    Mar 4, 2001
    1,707
    48
    kent
    +38
    hi can someone please advise me ??
    i have a wall mounted plasma and i will be wall mounting my front speakers too ,how far from the screen should i place the speakers
    thanks
    jason
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    If you have to wall mount then at least 6 feet apart to give you some kind of stereo image. The wider the better. 8-9 feet would be ideal. The centre will handle most of the dialogue and the L/R fronts will be effects speakers.
    Having the speakers a decent distance apart will also help if you play 2 Channel CD's through your system. The imaging and soundstage will be more accurate. improving the overall performance of the system.
  3. Roohster
    Roohster
    Jul 1, 2004
    3,790
    4
    2
    Derbyshire
    +3,817
    It depends on how far away from the screen you are sitting.
    One popular theory is the triangle - you should place the speakers the same distance apart as the distance you are sitting from them.
  4. jason t
    jason t
    Mar 4, 2001
    1,707
    48
    kent
    +38
    thanks
    jason
  5. Strobe
    Strobe
    Aug 29, 2003
    2,868
    Southampton
    +146
