Speaker Distance apart
Discussion in 'Home Cinema Speakers' started by xenole, Jul 16, 2005.
  1. xenole
    xenole
    Jan 2, 2005
    114
    Just got a new plasma stand (A3-B so approx 113cm wide) and until I get things sorted out, I've got all 3 front speakers on the stand (L and R at edges and centre on 28"tv).
    Before I had the L and R front speakers about 2-3ft either side of the tv.
    How much difference does this speaker positioning make to the sound? (B&W M1s)
  2. Barend
    Barend
    Apr 12, 2004
    804
    +9
    45 to 60 degrees from the listening sweet spot (depending on the radiation angle of the tweeter) should be OK.
    Height differences are not very important.
  3. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    Speaker interactions with the room are probably one of the most important factors in sound quality within a AV/HiFi system. The problem is in making generalised statements as each room is unique
  4. The Dude
    The Dude
    May 21, 2004
    5,136
    Beverley, East Yorkshire
    +1,406
    here's something I found on the web a few years back, I can't remember where unfortunately.. The results aren'y very living room friendly sometimes, but I do much prefer the sound of my system when I set the speakers using this..
    :lesson:
    Speaker placement, simply stated
    The distance from the center of the woofer face to the side walls is:
    Room Width times .276 (RW x .276)
    The distance from the center of the woofer face to the wall behind the speaker is:
    Room Width times .447 (RW x .447)
    This is all you need to know to place speakers in a symmetrical, rectangular room!
    :lesson:
    I think it was from an American DIY speaker site, or something similar...
