Speaker Dilemma!
Discussion in 'Home Cinema Speakers' started by tonybro, Jul 14, 2003.
  1. tonybro
    tonybro
    Jul 14, 2003
    24
    3
    Lancashire
    +4
    After moving into my new house I have a major dilemma with respect to speakers. The new fireplace gets in the way so I can't get my floorstanding speakers in now!
    As I also have floorstanding rears, they won't look right either so I am looking for some suitable replacements that are small enough to be wall mounted for both main and surrounds, I will also need a sub too as the smaller speakers won't go low enough...
    The B&W Centre I would like to keep unless there is a strong argument for getting rid.
    Power will come from a Denon AVC-A10SE/POA-T10 combination and this may be a problem as it could outclass some small units.
    Does anyone have any thoughts?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    If your budget runs to M&K, they certainly won't be outclassed by your amp
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Remove the fireplace - get central heating:clap:
