bootgaz
- Joined
- Feb 26, 2009
- Messages
- 247
- Reaction score
- 2
- Points
- 120
- Age
- 43
Currently in the process of building a new family room which will also be a home cinema. I have a setup in the lounger already but with the new build it allows me to upgrade kit and install everything in the walls / ceiling properly.
I have a real dilemma on what type of speakers to install and where. As you can see from my very dodgy sketch the screen will come down from the ceiling about half way in the room due to the one end housing a large desk.
My original plan was to install ceiling speakers for a 5.1 setup but not sure if this will give me the best sound possible with my layout. I then thought maybe in wall speakers but again what about the fronts and where can i put the centre speaker.
I would appreciate some help as i really want to order my speakers but just not sure which ones i should go with due to the way I will have my room setup.
I cannot change the layout so have to deal with the current situation.
Any help would be appreciated.
