Speaker Desk stands?
Discussion in 'Home Cinema Speakers' started by pragmatic, Jan 20, 2005.
  1. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    I have some mourdent short 302's on my desk i use with my pc but i want to rise them up slightly by about 6-12inches do such things exist (they are only little speakers).
    Otherwise what makes a good speaker stand and i'll have a go making my own.
  2. Chester
    Chester
    Aug 18, 2003
    3,297
    3
    137
    Peterborough, Cambs, UK
    +517
    Would you believe I was surfing the forums for an answer to this very question!
    I've seen plenty of surround speaker stands but quite frankly are not going to be large enough to copy with the likes of KEF Q15's or AE100's.
    Has anyone seen any solutions on their travels or can suggest a suitable alternative? Don't mind modifying something to make it work!
    Thanks in advance...
  3. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    My PC desktop speakers stand on some books :D
  4. Chester
    Chester
    Aug 18, 2003
    3,297
    3
    137
    +517
    Seen one solution: 200mm speaker stands from Apollo, available with different top plate sizes. It'll look a bit mad on a desk but it'll do the trick!
  5. Qublai
    Qublai
    Oct 24, 2005
    163
    +12
    IKEA used to do small stands that go on the floor and tilt the speakers back a little. Worth checking because I'm sure they were cheap.
  6. Chester
    Chester
    Aug 18, 2003
    3,297
    3
    137
    +517
    Can't see any on the Ikea webschite. A can only find satellite floor stands with concrete bases.
    Thanks for the pointer anyway.
  7. sennen
    sennen
    Nov 2, 2004
    103
    +6
    I bought a pair a few years back from Richer Sounds. Same sized top platform as their normal 50-quid bookshelf stands, with a base the same thickness and not much larger than the top platform, all approx 10 inches high. Check in-store, as it's not ones on their web site.
    HTH.
  8. cwuk
    cwuk
    I've got a pair about 17 inches high just gathering dust. You're welcome to them if they're any use to you, as long as you pay the postage which shouldn't be a lot. Perhaps you can shorten them easily.
    Anyway send a pm if interested.
    regards cwuk
  9. Chester
    Chester
    Aug 18, 2003
    3,297
    3
    137
    +517
    Thanks, that's very generous of you. I'm going to say no on the basis that 17" high stands on my desk would make the monitors reach over half way to the ceiling!
    Apparently Apollo do stands that go down to a height of 200mm, definitely seen them in the brochure at my local Sevenoaks, but can't find them on their webschite. Best order them and see what the outcome is!
    Cheers ;)
  10. cwuk
    cwuk
    Thats ok & good luck!
    If they're any good to anybody they're up for grabs, (just pay post) new condition, basic stands, sort of gold metalic not the heaviest but for nowt.......
    regards, cwuk
  11. Chester
    Chester
    Aug 18, 2003
    3,297
    3
    137
    +517
    Got the Apollo stands as above. They're a little on the large side, even for a 1600X800 desk, but they raise the speakers to a perfect height. I have ceramic discs for the spikes so they can be used to help reduce unwanted vibration and resonance.
