speaker dented
Discussion in 'Home Cinema Speakers' started by sdk, Apr 5, 2005.
  1. sdk
    sdk
  2. deanym
    deanym
    May 29, 2004
    1,833
    +143
    Sorry to see that mate. :(
    Is it a main speaker or surround? If a main get it fixed - call B&W direct and get them to send a tweeter then get your local dealer to replace it. Should be able to do lot for less than £30.
    Good Luck. :smashin:
  3. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Ouch! SDK,
    As Deanym has said if it's a main get it replaced. It will affect the stereo imaging of the speakers but they will still work, you won't damage them by continuing to use them.
    I'd get it replaced purely from the aesthetic point of view. I couldn't sit and look at it everyday.....:rolleyes:
  4. sdk
    sdk
    it is the left front.
  5. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    243
    You can use sticky tape to pull this out. Just be gentle with it.
    You need to make sure that the tape has as much contact as possible, and pull very gently on it.
    Fish
  6. sdk
    sdk
    Thanks i will give that a try. :)
  7. sdk
    sdk
  8. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,664
    I seriously doubt you could hear the effect of that mark now but see if your misses can help you do a blind test (moving it from left to right and so forth) if you want to be sure.
  9. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Nice Job!:thumbsup: I tried it once on some Tannoys, failed miserably! But that looks pretty good to me. I reckon you'd need some good ears to pick the difference now. Blind testing will be the crunch though.....
  10. add
    add
    Aug 6, 2004
    72
    Awesome tip, I'll be fileing that one in the "important little tips" section of my brain soimewhere.
  11. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    Another method that can also help, (now I want you to sit down, and I am serious), is to place your mouth over the tweeter and "suck" gently.
    Sorry, it is very difficult to put into word without laughing. But hopefully it will be helpful to someone someday.
  12. johnnycab
    johnnycab
    Jan 26, 2005
    84
    sdk,
    I did the same on my Tannoys recently. But, I was lucky due to the fact, that the tweeter unit had screws on either side - so it could be pulled out. I flattened it from the other side, and it looks exactly like the one on your fixed picture.
    With regards to the sound - there is not much difference, and in my opinion, it is just cosmetic. Also, I was doubly lucky that the tweeter unit came with the black metal grill - which I had removed as I liked the 'bare' look. I have replaced them since then, and everything is hunky-dory!
    BTW: I also saw exactly the same damage on a LRC-60 in a shop recently, and out of interest asked a sales guy - if it could be fixed. He just gave me a blank stare - which said it all!
  13. JonLeach
    JonLeach
    Sep 17, 2002
    755
    Deepest Darkest Yorkshire
    +22
    i had the same problem on my dynaudios when my Ex's nephew popped in. he pushed the tweeter in on my centre.
    Got the dyson out and carefully brought the hose closer to the tweeter and it popped it out, a little bit more dignified than sucking on your tweeter.
    Jon
  14. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,664
    Clever girl :laugh:.
  15. the mechanic
    the mechanic
    Nov 30, 2003
    1,232
    Wrexham,North Wales
    +52
    SDK,
    Nice woofer by the way (pic No 5)........... :D :D
    Seriously tho' good job on the tweeter.
    Graham.
  16. sdk
    sdk
    Thanks.
  17. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    243
    I like the model in pic number 6. ;)
    Fish
  18. sdk
    sdk
    It is the www.sidehsowtoy.com models, but they forgot to paint my helms deep model, that is the reason the helms deep model is there, needed proof when telling them. :) But they are nice. expensive as hell but real nice ( when they paint them that is)
