Kurgya
Apologies for diving straight into this but I’ve got a very basic audio setup in my home using a Samsung DVD player and 5.1 speakers.
The problem I’ve got is that it looks like the DVD player controlling the audio to the speakers has decided to stop working and I’m looking for a replacement for it but I can’t find anything that has the same connectors to the speakers.
The speaker out connectors look like the below (ignore the dust
Any ideas as to what they are called or just what to look out for?
Almost all the ones I can find have the pin outputs or the bare wire.
Thanks.
Thanks.
