Question Speaker connection
Discussion in 'Home Cinema Speakers' started by Hairballz9, Jun 16, 2017.
  1. Hairballz9
    Hairballz9
    Apr 1, 2016
    14
    4
    Leeds
    I've moved into a house that had surround sound in before and all the wiring behind the walls ready. However the rear speaker wiring doesn't have any connectors on. How would I connect speakers up?
    I know nothing about speakers/wiring or anything. FYI!
  2. adam-burnley
    adam-burnley
    Jun 17, 2007
    4,561
    Burnley
    +2,410
    Easiest way is to connect the bare wires directly to the speaker terminals, one wire to red and the other to black. You will need to look for some kind of marker on one of the wires so that you get the polarity right at the source (amp?) end.
  3. Jase
    Jase
    Mar 16, 2001
    10,942
    United Kingdom
    +3,362
    On the cables there are + and - markings. Just connect the + to Red and - to Black on your AV kit and speakers.
  4. adam-burnley
    adam-burnley
    Jun 17, 2007
    4,561
    Burnley
    +2,410
    You have good eyesight @Jase - although I am viewing on a smartphone so can't zoom in so much
  5. Jase
    Jase
    Mar 16, 2001
    10,942
    United Kingdom
    +3,362
    Me too. Zoom is pretty good on it though.:thumbsup:
  6. adam-burnley
    adam-burnley
    Jun 17, 2007
    4,561
    Burnley
    +2,410
    Must be my eyesight then, should put my reading glasses on!
  7. Hairballz9
    Hairballz9
    Apr 1, 2016
    14
    4
    Leeds
    Wow, that is some good eyesight. Thanks! It's just that it's bare wires, no end piece/connecter. Maybe when I get some speakers and see what they're like it'll make sense.
  8. Jase
    Jase
    Mar 16, 2001
    10,942
    United Kingdom
    +3,362
    You could get some Banana Plugs to make life easier when it comes to connecting it all up.
  9. adam-burnley
    adam-burnley
    Jun 17, 2007
    4,561
    Burnley
    +2,410
    Depends on the speakers though... cheaper ones tend to have the push-click type fittings. In fact, I have some Kef T301s and T101s that won't take banana plugs either.
    • Like Like x 1
    • Useful Useful x 1
    • List
  10. Jase
    Jase
    Mar 16, 2001
    10,942
    United Kingdom
    +3,362
    Ah, yes. Good point! :)
  11. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    20,537
    Inbetween Upgrades !
    +9,841
    @Jase
    You are awesome for spotting that :smashin:
  12. Hairballz9
    Hairballz9
    Apr 1, 2016
    14
    4
    Leeds
    Yeh they will be cheap ones too. I'm looking at sub £300. Not that I've chosen any. I'm picky! I want Bluetooth, tall front speakers and little wall rear speakers, and to make sure I can easily get the sound through tv and Xbox. And now I need to make sure they can take banana plugs!!! The search is on!
  13. Dolus
    Dolus
    Apr 26, 2005
    600
    46
    Gosport
    +186
    • Like Like x 1
    • Agree Agree x 1
    • List
  14. Hairballz9
    Hairballz9
    Apr 1, 2016
    14
    4
    Leeds
    So I bought some speakers but I can't connect them. The speakers have fixed wires. See pic for connection. Is there an easy way this can work?
  15. Jase
    Jase
    Mar 16, 2001
    10,942
    United Kingdom
    +3,362
    What speakers are they (can make out Samsung) as the connector looks like one you'd plug into a specific unit?
  16. Hairballz9
    Hairballz9
    Apr 1, 2016
    14
    4
    Leeds
    Yeh Samsung Ht j4500. I think I'll prob just return them! I asked before hand if they were fixed wires and they couldn't tell me!
  17. Jase
    Jase
    Mar 16, 2001
    10,942
    United Kingdom
    +3,362
    I think that's the best option. Ideally you want some speakers with proper binding posts and then you can use those banana plugs. :)
  18. Hairballz9
    Hairballz9
    Apr 1, 2016
    14
    4
    Leeds
    Thanks!
  19. Nayfne
    Nayfne
    Feb 3, 2013
    4,807
    5
    3
    north east
    +11,569
    I purchased the 2 pair of dedicated stands for fronts and rears on the KEF-T105 speaker set up..the stands allow for banana plugs[emoji106].
