Speaker connection question
Discussion in 'Home Cinema Speakers' started by BLACK_MAGIC, Jun 1, 2003.
  1. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    601
    manchester
    I have a set of speakers that i want to use with both my stereo amp and my surround amp. Currentley i have my main speakers plugged just into my stereo amp.
    Is it ok to plug it into my surround amp aswell by just plugging the the speaker cables from the surround amp with banana plugs into the back of the bannanas already in the speaker from my stereo connections.
    Providing i dont turn both amps on at the same time should this cause problem?
    I hope you understand what im trying to expalin. Any help would be great thanks.
  2. sounddog
    sounddog
    Dec 11, 2002
    3,370
    107
    Leicestershire, UK
    +461
    I would invest in a QED speaker switch box. Only cost you £30 or so and will save any risk of damage. They are also good enough quality not to affect sound quality.
  3. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    601
    manchester
    At the risk of sounding nieve what is a speaker switch box and how does it work?
    Also is there a way of actually doing this without having to spend more money eg a similar way to what i mentioned in my first post?
  4. mjn
    mjn
    May 24, 2001
    17,984
    Herts, England
    +4,950
    if you think about it for 5 seconds.....i think its pretty obvious what it does....
  5. ChrisNic
    ChrisNic
    May 11, 2003
    1,698
    48
    Thame
    +62
    As far as I know your inicial suggestion would work but for the cost of the extra cable you could have a speaker switch box as sounddog suggests. Why do you want to do this anyway, does your surround amp not have preout sockets?
  6. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    601
    manchester
    1..2...3...4...5. erm no its not, sorry we cant all be hifi technical freaks ive never seen one or even heard of such a device. Now please dont post again unless your going to be some help.
  7. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    601
    manchester
    No i just want to keep my musical amp and my surround amp seperate. One for dedicated music and the other for films etc.
  8. ChrisNic
    ChrisNic
    May 11, 2003
    1,698
    48
    Thame
    +62
    Usually a switch box means that you can run two sets of speakers from one amp, you just switch from one set or the other as you see fit. What they are suggesting is using it in reverse and switching between two amps to run one set of speakers. If im wrong just tell me and I will run away with my tail between my legs!
  9. sounddog
    sounddog
    Dec 11, 2002
    3,370
    107
    Leicestershire, UK
    +461
    Thats right cheapskate ... QED do some boxes that make sure you can only select one of the two imputs at once - a lot let you choose both outputs at once.
    The problem with your first suggestion is that you run the risk of shorting the amps out as internally there could be sufficient conductivity within the circuits even when they are turned off.
    To be honest ... I'd rather spend the £30 or so on the switch box than risk destroying 2 amplifiers. It's like it saves you money NOT having houshold insurance ... but I'm sure you make sure you are fully covered just in case.
    Vikki
  10. ChrisNic
    ChrisNic
    May 11, 2003
    1,698
    48
    Thame
    +62
  11. ChrisNic
    ChrisNic
    May 11, 2003
    1,698
    48
    Thame
    +62
  12. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    601
    manchester
    Thanks people ill go down my local hifi store next weekend and see if they have any switchs.:)
  13. sounddog
    sounddog
    Dec 11, 2002
    3,370
    107
    Leicestershire, UK
    +461
    What ever make you get ... make sure it will only let you select one set of speakers at once. Otherwise you still run the risk of lots of blue smoke ...
  14. mjn
    mjn
    May 24, 2001
    17,984
    Herts, England
    +4,950
    LOL...hifi freaks we may be...but you need our advice....
    plus, you don't need to be a genius to realise what a switch box does.....you know what a switch does, right??
    Switches, wil switch items/circuits off/on, or toggles between circuits.....in your case:
    2 signals from your amps, goes into a switch box, and one set of speakers are attached, and using a switch you will be able to listen to source A or B.
  15. sounddog
    sounddog
    Dec 11, 2002
    3,370
    107
    Leicestershire, UK
    +461
    BTW ... if you are talking about your Musical Fidelity A308 and Yamaha AX630 ... why not just plug the pre-out from the Yamaha for the fronts, into the A308 - I believe it has a direct to poweramp input.
    Vikki
  16. BLACK_MAGIC
    BLACK_MAGIC
    Feb 18, 2003
    601
    manchester
    Thank you:) thats made things alot easier:)
