speaker connection query
Discussion in 'Home Cinema Speakers' started by H4r7y, Jun 5, 2004.
  1. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    what are the advantages to connecting my front speakers up through my sub instead of going through my amp directly. would i notice a difference in movie or stereo mode?
    cheers
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    If I remember from people's comments it is best for stereo intergration.
  3. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    so for music duties it would be better? what about dvd's?
    thanks for the reply btw
  4. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    I would imagine you would miss out on the dedicated LFE channel even if it was directed to your main speakers.
  5. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    ive lost you now, could you explain a bit about what you said in your last post?
    thanks
  6. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    OK :lesson:
    With 5.1 (or 2.1/6.1/7.1) you have a dedicated Low Frequance Effects channel, the .1:) If you run the sub from the speakers there will be no signals to the LFE. Then you will have to tell the amp to direct the LFE signals to the main speakers. The sub will then pick up on the LFE signels that are being sent to the main speakers and output some itself but you will have to set the subwoofer up yourself (crossover frequancy).
    If you used the sub directly connected to the sub all the LFE channel signals will be sent to the sub with the amp controling the crossover.
    In Stereo there is no LFE so either the amp directs some to the sub or you have the sub between the speakers to pick it up directly. :lesson:
    I hope this explains it a little better. :smashin:
  7. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    yeah its clicked with me now, so its better for stereo then as it will produce a much more matched and balanced effect from the high to the lows? and it sounds a bit fiddly to setup for dvd's and im not too keen on losing the dedicated lfe signals getting to the sub.
    thanks for the explanation
  8. Nimby
    Nimby
    Jan 27, 2004
    9,204
    The Danish Bacon Factory
    +671
    Well if you understand it now you might like to explain it to me. :laugh:
    In addition to Dfour's post & for stereo listening only:
    Option1) Connect Left and Right speaker cables from amp to main speakers as normal. The sub's L & R Input terminals are also connected (by another pair of speaker cables) to the same Main speaker amplifier terminals. (Maintaining stereo and polarity)
    The main speakers are running full range. Producing as much bass as they are capable of. The sub is set to a low cut-off frequency to avoid overlapping the stereo speaker's bass output.
    Option 2) The sub only is connected (from the Left and Right Input terminals) to the Main speaker terminals on your amplifier. You connect your speakers only to the subwoofer's L & R Output terminals. The sub then acts as a (stereo) crossover between subwoofer and speakers. Saving your main speakers (and amp) some bass effort.
    The sub now produces all of the bass and the speakers everything above the setting on the crossover frequency control. This is usually at around 80Hz. The sub must be fed with stereo in both options even though it can only play in mono itself. The sub amplifier's circuitry ensures stereo is maintained for the high level Output terminals.
    A third (and fourth) option would involve two subwoofers. One for each channel. Left & Right. Either connected direct or via the sub's crossover as in options 1 & 2.
    I hope this helps to fill out Dfour's much briefer explanation.
    I should also have added that option 1 is the preferred method. Only you can say whether option 2 is inferior. (It adds a level of filtration that might spoil the sound quality)
    Nimby
  9. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Thx Nimby that fills in some holes of my knowledge to :D I love these forums ;)
  10. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    so, if i did option 1 i would have the speakers hooked up twice then? once from the amp and then again from the output on the sub? how would this work when playing movies?
    thanks guys
  11. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    NO i dont think you can do that safely. Its either one or the other.
    MY 309 manual says DO NOT CONNECT HI AND LOW LEVEL CONNECTS At THE SAME TIME. :nono:
  12. Nimby
    Nimby
    Jan 27, 2004
    9,204
    +671
    Sorry. I was assuming (wrongly) that your sub could be connected to high and low at the same time. :blush:
    Which is true for REL, SVS and (I believe) MJA. B & W are low level only on the models I've studied.
    If it's a case of either/or (hi or low) then just go with the usual LFE or Sub-out phono socket. (low level connection)
    The high level connections are really for the highest possible quality stereo music enjoyment. Or for those who still like to use a high quality 2 channel stereo amp for everything.(including films)
    So, forget everything I've said so far. Unless you do have high level connections (speaker type terminals) on your sub and are allowed high and low level connections at the same time. Just keep it simple and feed your sub direct from your 5.1 receiver or 5.1 amp. :)
    Nimby
  13. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    ive just looked in my manual and it does state not to use both at the same time. so ill leave it the way ive got it.
    thanks guys
