Speaker Connection Queries (NEWBIE HERE)
Discussion in 'Cables & Switches' started by 3sgte_power, Jun 23, 2005.
  1. 3sgte_power
    3sgte_power
    Jun 7, 2005
    887
    28
    Coventry
    +45
    sorry guys i am a bit of a newbie at this stuff and i am after a bit of help, so i don't end up getting ripped off...
    I am about to purchase some loudspeaker cable (Merlin C6) for my Linn Classik / AVI Neutron setup.
    Can anyone tell me what kind of speaker plug connection thingy the Linn Classik uses? I've never seen anything like this!
    Also what kind of connection do i need at the speaker end (AVI Neutrons)? Some kind of banana plug or what?
    Thankyou
    PS: Are the Merlin C6 a good speaker cable?
  2. rowlandhills
    rowlandhills
    Feb 9, 2005
    427
    Baldock
    +18
    I can't tell you anything about the AVI Neutrons, but the Classik uses a connection known as a BFA connector (http://www.british-audio.org.uk/connectors.htm). You can often buy these on eBay, or from somewhere like hifistore (http://www.hifistore.co.uk/product.php?qsProd=CC124).
    I've wound up getting 5 pairs with my Classik Movie Di and 5 with my AV5125, which means that I have all the connectors I need for biwiring, but I'm afraid I don't have any spare.
    In terms of the speaker cable, I'd take a look at Van Damme (see various threads on here, do a search and you'll get a load of results). I'm using Van Damme 4x2.5mm black series to connect my AV5125 to my Linn Keilidhs, and it sounds very nice to me.
    Good luck.
    Rowland
  3. 3sgte_power
    3sgte_power
    Jun 7, 2005
    887
    28
    Coventry
    +45
    Thanks mate...i brought the BFA connectors / banana plugs off ebay a couple of days ago, and have just fisnished connecting them up to some merlin c6 speaker cable. Sounds really nice. Definately a step up of from the Linn K100 speaker wire i had before! Seems more lively to me!
    Thankyou
