Speaker Choice
Discussion in 'Home Cinema Speakers' started by chino, Jan 19, 2003.
  1. chino
    chino
    I'm looking to buy some Monitor Audio Silver 6's anyone got any opinions on these?
    I would also like some suggestions of other speakers to test around the £600 mark (preferably no more than). I've tested them against Kef Q5's and am planning to listen to some B&w 603's.
    All advice and opinions welcome,
    Chino
  2. rozzar
    rozzar
    Sep 29, 2002
    1,056
    41
    Braintree
    +23
    hi Chino
    Firstly, i must congratulate you on your choice of speakers-the Mordaunt Short 902s- fabulous underrated speakers- on Atacama Se6 filled stands, they show up the rest of the Mordaunt Short range- up to the £500 908s - believe me- I'm a hifi dealer and I sell more 902s than any other speaker...for that reason, I'd recommend for your £600 to get a NAD power amp to biamp the 902s and to get a far more charismatic CDP- Arcam CD72 springs to mind.
  3. chino
    chino
    Thanks for your reply, an amplifier will probably be my next upgrade after speakers - probably the NAD power amp.
    Anyone got any opinions/advice on speakers for £600?
    Chino
