speaker choice ?
Discussion in 'Home Cinema Speakers' started by DodgeTheViper, Nov 2, 2001.
  1. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,685
    Inbetween Upgrades !
    +8,121
    I,m considering either the M&K K7 - Series speaker system or the Kef THX Ref system. I will probably be using the Denon 3802 Amp. Does anyone have either of the above or perhaps even the same set up ?
    What do you think would be the pro,s & con,s of the suggested set up ?
    Any guidance would be greatly appreciated.
    Kev
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    KEF Reference, because it is British.
    :p
    Both are excellent but I felt there was better performance and value from KEF on this one.
  3. Guest
    By far the best answer is to find a local dealer who stocks both brands and get a demo!
    There really is no substitute for being able to make a/b comparisons.
    If you cant find a dealer who stocks both, at least try to audition the two alternatives on the same day.
    Other peoples opinions may help your decision, but trust your ears! :cool:
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    My vote goes with the MK K-series speakers. Just as good with music as the KEF THX reference, and much smaller and cheaper.
    You'll want the K3 package with an extra pair of K4 tri-poles, cost you around £2,400 altogether.
    Where do you live? We have the K3 system resident in our AV demo room, running off an Arcam AVR 200.
