speaker change
Discussion in 'Home Cinema Speakers' started by el bandido, May 19, 2003.
  1. el bandido
    el bandido
    I have a yamaha receiver which i'm really happy with, and the yamaha nsp220 speakers that come in yamaha's package HTIB45
    the centre speaker can be alittle weak, and was thinking about replacing the from three speakers with mission M70s and the M7 centre
    overall about £140
    will I get a big benefit from this?
    Thanks in advance
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Probably "some" improvement, but not a big one IMO. Look at speakers in the class above the Mission M70's. Try Wharfedale 8.1/2, Mission M71i, Kef Coda 70, B&W DM303, etc. Your amp is capable with better speakers and can improve the front soundstage plenty.
  3. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,091
    notts.
    +64
    Hi El Bandido
    I used to have the yamaha htr-45 i changed the front three for mission m71is and mission m7c2 centre the differance was massive i sold these speakers on this forum for £125 only 6 months old so keep your eyes peeled on the classifieds and you should be able to pick a front three up second hand. most people on the forums are honest so dont be afraid to buy secondhand as you could pick up a bargain.
    Cheers Gonzo. :)
