Speaker calibration with SPL
Discussion in 'Home Cinema Buying & Building' started by Brad_Porter, Mar 11, 2003.
  1. Brad_Porter
    Brad_Porter
    Guys,
    I know how to calibrate my speakers with an SPL (Radio Shack Digital) but rememeber a point from Nic Rhodes about 'always calibrating/reset before the next reading'.
    On the Radio Shack SPL, there is indeed a hole that says 'CAL'. I gather this means calibrate and wonder how I can use this to get the best and most accurate readings; if at all.
    Regards,
    Brad
  2. nathan_silly
    nathan_silly
    DON'T PRESS THE BUTTON!
  3. Dirk Dingo
    Dirk Dingo
    As Nathan has said "DON´T PRESS THE BUTTON!":suicide:
  4. Brad_Porter
    Brad_Porter
    Why? What happens? Does a small exploding device erupt causing facial damage? :D
    Whys that then?
  5. Dirk Dingo
    Dirk Dingo
    Because you´ll bugger it up. Better to have it reasonably accurate than not at all.:lesson: ;)
  6. Brad_Porter
    Brad_Porter
    Thanks.........
  7. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    I calibrate my SP meter every month or so, it's rarely out by more than 0.5dB, so i'm not sure it's that important, from an AV perspective.
