Speaker cables +/-
Discussion in 'Home Cinema Speakers' started by weyland-yutani, Sep 13, 2003.
  1. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    I know this might be a stupid question but when connecting speaker cables, can you connect any side of the 2 wires to any terminal as long as they correspond to the other end connected?
    And, does cable speaker have to be shielded as i'm going to have a tough time keeping each indvidual cable away from any other. I always thought/heard that as long as power and signal cables don't run parralel to each other its ok for them to touch/cross?
    Thanks.
  2. Big Adam
    Big Adam
    May 7, 2003
    527
    Peterborough
    +4
    Yes
    No, that's fine. Running parallel is fine too. The only thing you want to avoid is excessive coiling of excess wire. It's preferable to trim the excess off.
  3. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    thanks
