D
DaveP
I'm upgrading my amp and some of my speakers so I thought it would be a good idea to do the cables at the same time.
The question is: how much should I pay per metre for the cable and where is the cheapest place to buy it?
With Scart cables it seems generally accepted that you should spend about £20 each to get a decent quality cable. Can the same be said for speaker cable? Is there a point where you can say you get the best value for money?
Dave
Dave
