Speaker cables running next to power?
Discussion in 'Cables & Switches' started by chalkstorm, Oct 25, 2005.
  1. chalkstorm
    chalkstorm
    Jan 19, 2004
    433
    Rugeley
    +8
    I'm in the process of converting a room into a HC - and I've bought shielded speaker cables - and Chord Silver HDMI cable. They all run in a bundle around the top of the room - next to the power cables. I am assured by my local specialist shop that it will be OK - but I've read elsewhere on here that I could have problems with noise from my speakers.
    Any thoughts? Tonight is the last chance I get to re-route them all before they are covered with plasterboard!
    Thanks in advance
    Simon
  2. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,672
    Try it first.....assuming all of the cables are already laid,why not just give it a trial run before the plasterboard is placed.
    It probably won't give you any problems,especially using shielded cables,and also bearing in mind that that the speaker feeds are a relatively high level line,and the levels of 50Hz mains interference will be very small by comparison.
  3. chalkstorm
    chalkstorm
    Jan 19, 2004
    433
    Rugeley
    +8
    Ahhh... I would love to try it... but...
    Once fully boarded the room will be skimmed - and then the heating will go in. Only after that, and decorating/carpeting will I start to actually buy the kit! You can see I am some weeks away yet....
    Think I'll go with what my local specialists say...
    Thanks again for your quick response - it has put my mind a rest
    Simon
  4. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    Horses for courses I think. I have mains and speaker cables all tangled around each other behind my unit. It was a case of plug it in and throw all the cables down the back and out of sight and never gave it a second thought that there could be interference. Needless to say, after 2 years, I've yet to hear a hiss or a hum.
    It's just one of those things where people tell you not to plug your amp or subwoofer into the same power socket incase of interference (or blowing either up :D ). Again, I have no problems and that's with the amp, subwoofer, TV and DVD player all connected to one four way extension cable.
  5. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    Yep,
    I was always gonna seperate out my snake pit of cables eventually, to hopefully trim out all the unwanted electrical noise.
    But having tried a Nordost Interconnect which apparently has no shielding, my power amp decided it would like to hum along as well. I tried turning the pre sideways and have the power in the middle of the floor cable away from the snakes and it seemed to work, say 98% happy with the lack of hum :clap: . Other cables (regarding humming amps) with shielding seem to be fine with all the others....... :clap:
    If I was to go for the Nordost I don't quite know how I would have the kit arranged...... :confused: :eek:
  6. GW43
    GW43
    Feb 27, 2005
    1,662
    63
    Out of my mind on dope and speed
    +169
    I have speaker cables (Van Damme blue - unshielded, nothing fancy!) running in parallel with power cables for short distances (2-3 feet max), and had no noticable problems.
    If you've already done the plastering, then you should (hopefully) be ok!
  7. chalkstorm
    chalkstorm
    Jan 19, 2004
    433
    Rugeley
    +8
    Fingers crossed I'll be OK. The maximum run of speaker cable is 35 feet - for the front right speaker. It runs along with a bundle of power cables (ring main and lighting) - tied into the same bundle -
    Time will tell....
    Thanks all
    Si
